Manufacturing Solutions
Workpiece Material Models
Inside the user profile, materials are assigned for the workpiece (billet) and the boundary faces of the workpiece components.  HX-Forge supports the following three constitutive models for metals:
1.Inverse Sine Hyperbolic model
2.Metal Forming Power Law model
3.Norton-Hoff model
Workpiece Material Properties Data Types
The following table contains descriptions of data types for Workpiece material properties:
Variable Name
Value Type
Remarks
ConstitutiveModel
String in quotes
"SineHypInv"  "PowerLaw"  "TemDependentNortonHoff"
Density
Real (Constant)
Density of the fluid
SpecificHeat
Real  (Constant/Function of Temp.)
Function can be a TABLE1 or EXPRESSION
Conductivity
CoeffOfThermalExpansion
Real (Constant)
Thermal expansion coefficient
VolumetircHeatSource
Real (Constant)
Value per unit volume
SolidusTemperature LiqidusTemperature
Real (Constant) Real (Constant)
Friction coefficient decreases from its full value at SolidusTemperature to zero at LiqidusTemperature
Temperature Dependence
String in quotes
"None"
"Coefficients"
"Exp(Q/RT)"
"Exp(-Beta(DeltaT))"
"Exp(A1T+A2T^2)"
Amplitude  ConstantY
Only for PowerLaw with "Coefficients" for Temperature Dependence
Other Data
Real (Constant)
Data specific to different material models is described in the following sections.
