Manufacturing Solutions
untrim subpanel
untrim subpanel
untrim subpanel
Allows you to remove trim lines so that the trimmed surfaces return to their previous, untrimmed state.
Panel Input
Input
Action
at cursor: edge
Will remove a single, specific trim line.
surface_edit_untrim_basemodel
standard_arrow_beforeafter
surface_edit_untrim_at_cursoredge
Here, clicking each of the circular trim lines (holes) removes the trim and extends the surface.
all trim lines of surfs: surfs selector
Will remove all of the trim lines on one or more surfaces that are selected.
surface_edit_untrim_all_linesofsurfs_after
Here, picking the front face surface trims all of its lines, including the one forming the hole in its center.
Selected trim lines of surfs: lines
Use this selector to pick specific trim lines so that you can untrim portions of the surface.
surface_edit_untrim_before
The arrows indicate edges picked.
surface_edit_untrim_after
Each selected edge us untrimmed
Selected trim lines of surfs: shortcut/ extend
This determines how the surfaces are untrimmed.
shortcut generates a straight line between vertices.
surface_edit_untrim_before_shortcut
surface_edit_untrim_after_shortcut
extend attempts to follow existing geometry by extending the edges using adjacent edges as a guide.
surface_edit_untrim_before_extend
surface_edit_untrim_after_extend
Selected trim lines of surfs: keep vertices
When checked, the points denoting vertices remain even after untrimming.
internal trim lines: lines selector
Will remove one or more trim lines inside the boundaries of the surface selected.
surface_edit_untrim_internaltrimlines_after
Here, clicking each shared edge line removes it, stitching the adjacent surfaces.
See also
Surface Edit panel
