Manufacturing Solutions
Unit Selection
Unit Selection
Unit Selection
The HyperForm RADIOSS One Step solvers and RADIOSS Incremental solvers are unit neutral. However, it is important to maintain unit consistency.
The following units are recommended for RADIOSS One Step analysis:
Measure
Recommended Unit
Length
mm
Stress
MPa
Blankholder force on elements
metric ton: 1 ton = 9810N
Blankholder force on edge
N/mm
Drawbead force
N/mm
The following units are recommended for RADIOSS Incremental analysis:
Measure
Recommended Unit
Length
mm
Stress
MPa
Blankholder force
N
Drawbead force
N/mm
Density
Mg/mm3
Time
s
Velocity
mm/s
See Also:
User's Guide
