Manufacturing Solutions
Material Variables
Material Variables
Material Variables
The variables for the material update parameters are:
E
Young’s Modulus
YS
Yield Stress of material
K1
Strength coefficient (power law equation P-L-equ )
E04
Pre-strain coefficient
n
Strain-hardening exponent (measures stretch ability/work hardening of material)
r
Plastic strain ratio (measures deep draw ability of material)
Note:   Material units must be consistent for all parameters.
The following equations are commonly used to calculate K1 and E04:
MV-TS
MV-YS
Where:
e        =        2.718
TS        =        tensile strength
YS        =        yield stress
Some common unit conversions are listed below:
USCU – SI
SI - USCU
Length
1 in = 25.4 mm
1 mm = 0.03937 in.
Force
1 lb = 4.448 N
1 N = 0.2248 lb
Stress
1 Ksi = 6.895 Mpa
1 Mpa = 0.145 Ksi
Mass
1 lbm = 0.4536 kg
1 lb = 0.0005 tons
1 kg = 2.205 lbm
1 ton = 2000 lbs
Gravity
gravity1
gravity2
See Also:
User's Guide
