Manufacturing Solutions
Tool Offset
Tool Offset
Tool Offset
The Tool Offset subpanel allows you to create new tool components by offsetting existing shell elements.
To offset elements or components:
1.Select the elements or component to be offset.
2.Enter a distance value.
3.Select rounded or square corners.
4.Select the destination component.
5.Click offset.
See also
Tools
