Manufacturing Solutions
To create torus surface primitives by specifying three nodes
1.Select the Surfaces panel, torus three nodes subpanel.
2.Click on the major center collector and select a node from the graphics area.
3.Click on the minor center collector and select a node from the graphics area.
4.Click on the minor radius collector and select a node from the graphics area.
5.Click create.
6.To undo, immediately click reject.
