Manufacturing Solutions
To create surfaces by dragging nodes along a line
1.Select the Surfaces panel, drag along line subpanel.
2.Set the collector to node list and select the relevant nodes to drag.
3.Click on the line list collector and select the drag along lines in the proper order.
4.Set the frame mode to specify how the node list is translated and rotated during the drag.
5.Set the reference node method to translate the drag line prior to the drag.
If set to default, there is nothing to input.
Or
If set to node, select a node.
6.Set the transformation method to translate and rotate the input nodes prior to the drag.
Or
If set to with plane, define the plane using the plane/vector collector.
7.Click drag + or drag -.
8.To undo, immediately click reject.
