Manufacturing Solutions
To create square surface primitives
1.Select the Surfaces panel, square subpanel.
2.Use the plane collector to specify the desired plane.
3.Use the b collector to specify the base node.
4.Enter the size of the square.
5.Click create.
6.To undo, immediately click reject.
