Manufacturing Solutions
To create sphere surface primitives by specifying the center and radius
1.Select the Surfaces panel, sphere center and radius subpanel.
2.Click on the center collector and select a node from the graphics area.
3.Set the radius method to determine how the radius is specified.
Enter the radius value.
Or
Click on the r node collector and select a node from the graphics area.
4.Click create.
5.To undo, immediately click reject.
