Manufacturing Solutions
sphere center and radius subpanel (Surfaces panel)
This subpanel creates three-dimensional sphere surface primitives by specifying the center and radius.
Two inputs are required to create a sphere using this method:
The center node defines the center of the sphere.
The radius defines the sphere radius.  A value can be specified, or a node that defines the radius (measured from the center node) can be selected.
surfaces_sphere_centerandradius_example
How do I…
Create sphere surface primitives by specifying the center and radius
See also
Surfaces panel
