Manufacturing Solutions
To create partial torus surface primitives
1.Select the Surfaces panel, torus partial subpanel.
2.Click on the center collector and select a node from the graphics area.
3.Click on the normal collector and select a node from the graphics area.
4.Click on the major axis collector and select a node from the graphics area.
5.Set the major radius method to determine how the major radius is specified.
Enter the major radius value.
Or
Use the major axis node.
6.Enter the major start angle value.
7.Enter the major end angle value.
8.Set the minor radius method to determine how the minor radius is specified.
Enter the minor radius value.
Or
Use the normal vector node.
9.Enter the minor start angle value.
10.Enter the minor end angle value.
11.Click create.
12.To undo, immediately click reject.
