Manufacturing Solutions
To create full cylinder surface primitives
1.Select the Surfaces panel, cylinder full subpanel.
2.Click on the base node collector and select the base node from the graphics area.
3.Click on the normal vector collector and select a node from the graphics area.
4.Enter the base radius value.
5.Enter the height value.
6.Click create.
7.To undo, immediately click reject.
