Manufacturing Solutions
To create fillet surfaces
1.Select the Surfaces panel, fillet subpanel.
2.Optionally, check on or off the auto select whole edge checkbox.
If enabled, set the appropriate values for pick angle and x stop control.
3.Click the lines collector and select the relevant surface edges.
4.Optionally, click on the edit fillet options button to access advanced settings.
If used, set the appropriate values for the options and click return.
5.Enter the radius value.
6.Click create.
7.To undo, immediately click reject.
