Manufacturing Solutions
To create a single JPEG image from an animation file
1.Select the options panel.
2.Select the postscript subpanel.
3.Use the slider under jpg quality to set the desired resolution of the image.
The resolution is displayed in the status bar.
4.Update the reverse video check box to set the background color.
When this option is on, the JPEG file is generated with a white background.
5.Click return.
6.In the animation panel, set the rightmost toggle to manual.
The animation panel is displayed when you use the deformed or transient panels.
7.Use the slider bar to select the desired frame.
8.Press CTRL-F6.
