Manufacturing Solutions
To create a 3D spline surface by selecting nodes or points
1.Click the leftmost switch and select nodes or points.
2.Indicate the nodes or points that define the edges of the surface:
Pick the nodes/points on your model.
or
Use the extended entity selection menu.
HM_Panels_bmp00318
3.Click the switch and select the desired mesh and surface option.
4.Click create.
HM_Panels_bmp00319
Undo
Click reject immediately after creating the surface.
