Manufacturing Solutions
To create a 3D spline surface by selecting lines
1.Click the leftmost switch and select lines.
2.Indicate the lines that define the edges of the surface:
Pick the lines on your model.
or
Click lines and choose from the extended entity selection menu.
HM_Panels_bmp00316
3.Click the switch and select the desired mesh and surface option.
4.Click create.
HM_Panels_bmp00317
Undo
Click reject immediately after creating the surface.
