Manufacturing Solutions
Autoposition
Autoposition
Autoposition
Two methods are available to position components:
Two parts
Multiple parts
To Autoposition Components (Two Parts)
1.Click translation part: comps and select the components to translate.
2.Click reference part: comps and select the components that are to remain stationary.
3.Select toggle w/reference.
4.Define the direction of approach to autoposition the component.
5.Click adjust to autoposition components.
with reference: the translation part is adjusted with respect to the reference part based on the direction specified.
without reference: you must specify x, y and z translation for the translation part.
To Autoposition Components and Define Contacts (Multiple Parts)
1.Click punch: comps, and then select the punch component.
2.Click binder: comps, and then select the binder component.
3.Click die: comps, and then select the die component.
4.Click blank: comps, and then select the blank component.
5.To define contacts between the tools and blank, select the checkbox for create contact with blank.
6.Define the moving part as the punch or die.
7.Define the direction of the moving part.
8.(LS-DYNA only) If required, specify the drawbead height (db ht).
9.Click adjust.
See also
Tools
