Manufacturing Solutions
To add nodes to the temporary node mark
1.While nodes is highlighted, indicate the nodes that you want placed on the temporary node mark:
Pick the nodes on your model.
or
Click nodes and choose from the extended entity selection menu.
2.Click add.
