Manufacturing Solutions
Solid Fluid Interface
This boundary condition is used at the interface between two different materials. Typically, one of them is tool and the other one is the deforming material. An example is a Container and Billet in metal extrusion. The Container is the tool and the billet is the workpiece. This BC can also be used between tool and tool, as in the case of dummy block and container.
The syntax for this boundary condition is:
SolidFluidInterface SFinterface {
                          ([X_Velocity = Ux, Y_Velocity = Uy, Z_Velocity = Uz]) |
              FrictionModel = "string",
                            FrictionCoeff = C,
                            SlipVelocity_X = Uwx, SlipVelocity_Y = Uwy, SlipVelocity_Z = Uwz,
                            SlipVelExponent = m)
                            ContactBCName = "String"
                            Temperature = T | HeatTransferCoeff = h
                            Strain = e}
Here SFinterface is the name of the solid wall boundary and is specified by you. For the momentum equation, specify either velocity components, or friction coefficient and slip velocities for friction condition. For FrictionModel, the string must be inside double quotes. Even this is optional. If none are specified, the program initializes them to zero (stationary walls). On the other hand, if the velocities are specified, the program treats the problem as a moving interface problem and for each time step the program computes the grid velocities before moving the nodes. The friction at the tool-workpiece interface is computed using the specified friction model. The name of this model must be specified inside double quotes. Refer to the section on friction model to learn more about the supported friction models.
Valid data types for SolidFluidInterface boundary conditions:
Variable Name
Valid Data Types
Velocity (Ui)
Velocity component (i=x,y,z)
CONSTANT, EXPRESSION f(x,y,z,t)
FrictionModel
Friction model
{SlipVelocity | Coulomb | Viscoplastic }
FrictionCoeff
Friction Coefficient
SlipVelocity_i
Velocity vector of the boundary in the slip direction
SlipVelExponent
Exponent of slip velocity
CONSTANT (only for PowerLaw model)
ContactBCName
Name of BC on contact surface
String
Temperature
Temperature at the boundary
HeatTransferCoeff
Heat transfer coeff at gap between tool and workpiece
CONSTANT
Strain
Workpiece strain at boundary (Typically used at ram/dummy block and billet contact surface)
CONSTANT
See Also:
Boundary Conditions
