Manufacturing Solutions
Free Surface
Free Surface
Free Surface
BC_Type = FreeSurface: This boundary imposes zero normal velocity at the surface.
Syntax for this boundary condition:
FreeSurface Boundary_Name { ( Temperature Tfs | HeatFlux = qfs | ConvCoeff = hc, ConvTref = Tinf ) }
Variable Name
Valid Data Types
Temperature (Tfs)
Static temperature
CONSTANT, EXPRESSION f(x,y,z,t)
HeatFlux (qfs)
Magnitude of surface heat flux
ConvCoeff
Convective heat transfer coefficient
ConvTref
Outside temperature
If MeshUpdate analysis is being done, the FreeSurface boundaries are allowed to move to remain tangent to velocity vectors.
See Also:
Boundary Conditions
