Manufacturing Solutions
Solid Material Properties
The Solid material type is a parameter used with the BEGIN MATERIAL data block. This material must be used when solving conjugate heat transfer problems. For Solid, HyperXtrude allows you to specify the conductivity in the form of diagonal tensor.
Solid
Steel
Density =
ρ
SpecificHeat =
Cp(T)
XConductivity =
K(T)
YConductivity =
K(T)
ZConductivity =
K(T)
VolumetricHeatSource =
Qvol
CoeffOfThermalExpansion  =
β
YoungModulus =
E
PoissonRation =
ν}
Specific heat and thermal conductivities can be input as functions of temperature. The following table contains descriptions of the data types for solid material properties:
Density
Real (Constant)
Density of tool material
SpecificHeat
Real  (Constant/
Function of Temp.)
Function can be a TABLE1 or EXPRESSION
XConductivity
Real (Constant/
Function of Temp.)
YConductivity
Real (Constant/
Function of Temp.)
ZConductivity
Real (Constant/
Function of Temp.)
VolumetircHeatSource
Real (Constant)
Value per unit volume.
Real (Constant)
Coeff of Thermal Expansion
YoungModulus
Real (Constant/
Function of Temp.)
Young's modulus of tool material
PoissonRatio
Real(Constant)
Poisson ratio of tool material
See Also:
Element Information
Material Models
Fluid Material Properties
Workpiece Material Properties
Polymer Material Properties
Tool Material Properties
