Manufacturing Solutions
shrink subpanel
shrink subpanel
shrink subpanel
Shrinks the surface by drawing all of its edges (including internal edges from holes, and so on) "back" away from their starting location.
For example: if you shrink a square surface that has a circular hole in the center, the square would become smaller but the circular hole in its center would become larger, because the edge of the hole draws "backward" (that is further into the surface).
Example:
shrink_surface_selected
The black surface has been selected.
shrink_surface_shrunk
The edges of the selected surface pull inward, away from the initial edge locations.
Panel Input
Input
Action
surfs selector
Select the surfs to shrink.
offset
This is the distance that each edge of the surface moves further into the surface.
Note:Holes in the surface will get larger, not smaller, as their edges move further into the surface instead of out into the empty space bounded by the hole.
See also
Surface Edit panel
