Manufacturing Solutions
*setup_trimming
*setup_trimming
*setup_trimming
SYNTAX
*setup_trimming
TYPE
Incremental DYNA Commands
ARGUMENTS
entityattributetype markmask, int list, int curve_dir, int curve_flag, double tolerance
DESCRIPTION
Apply trimming setup for selected components at markmask
lsit: trim line list
curve_dir: vector id for direction
curve_flag: -1 remove outside elements 1 remove inside elements
tolerance: LSD_TCTOL
