Manufacturing Solutions
Commands
Commands
Commands
Command files are standard ASCII files that HyperForm can read or write. Command files allow you to retrieve a work session in case of a system crash or program a series of procedures. You can use command files in applications containing repetitive steps. You can also use them to create demonstrations.
During each modeling or post-processing session, HyperMesh generates a command file named command.cmf. This file is created at the start of a HyperMesh session if it does not exist. If the file already exists, HyperMesh adds the commands for the new session to the end of the original file.
For details about how to use command files, refer to the links below to HyperMesh documentation.
