Manufacturing Solutions
Set Process Conditions
In this tab, the parameters for boundary conditions are set. Select the type of process condition at the inlet by selecting the appropriate option. If Melt Flow Rate is selected, it is converted to Melt Velocity by using the area of the inlet face. Specify the Mold Temperature. Click on Next.
runner_balancing_06
In this tab, select the inlet and outlet surfaces of the runner system. Click proceed after graphically selecting the surfaces. When surfaces have been selected successfully, the Pick button will display green.
runner_balancing_07
Click OK to complete the task.
