Manufacturing Solutions
Set Analysis Requirements
Previous topic Next topic Expand/collapse all hidden text
The next checkbox is Set Analysis Requirements.
In the step, you will have to answer a series of questions to describe the model under consideration. Each equation has only two valid answers and the dialog will help you pick one of them. These requirement questions are grouped together.
hmtoggle_plus1greyPage 1 - Process Data
This page has all the questions related to model and type of analysis.
coextrusion_05
hmtoggle_plus1greyPage 2 - Analysis Data
This page includes few analysis questions.
coextrusion_06
hmtoggle_plus1greyPage 3 - Advanced Meshing Data
This page has advanced meshing control questions. Currently models with existing mesh are not supported.
coextrusion_07a
hmtoggle_plus1greyPage 4 - Select Components
In this page:
for every component, select the applicable layer
on each layer, select the type of material to be assigned
Right click on each item to assign it to the highlighted object.
coextrusion_08
hmtoggle_plus1greyPage 5 - Inlet/Outlet Surfaces
In this page, select the inlet and outlet surfaces for each layer of Polymers.
Click Next to proceed to the next page.
coextrusion_10
hmtoggle_plus1greyPage 6 - BCs and Process Conditions
Select the BC parameter data. Click OK to save and close the Set Analysis Requirements tab.
Click OK to save all the selections of the Set Analysis Requirements tab.
coextrusion_09
