Manufacturing Solutions
Select Material Data
The second checkbox under Set Process Data in the Coextrusion Analysis Wizard tree is Select Material Data. Select and add polymer materials. If the model has insert and tool, select tool materials also. Clicking Close assigns the selected material.
coextrusion_04
