Manufacturing Solutions
Selecting a Material from the Database
1.From the RTM Utility menu, click Material Data. The Select and Assign Material from Database dialog is displayed.
2.Using the tree in the upper left portion of the dialog, expand the System materials categories to find the material you want to select.
3.Click the Add button. The material will appear in the Selected materials list on the right. This action adds the material to the HyperMesh database.
4.Click Close.
material_database_rtm_02
