Manufacturing Solutions
Select and Assign Material
The fourth checkbox on the Extrusion Wizard tab is Select and Assign Material.
Select and add a Workpiece and Tool material. Adding a Workpiece material is compulsory, whereas the Tool material needs to be selected only when there are Tool components. Clicking Close assigns the selected material to the respective Workpiece and Tool.
select_and_assign_materials
If the selected material is not supported by the press selected in Select Press Data, then the following message is shown.
press_error_message
