Manufacturing Solutions
Model Setup
Model Setup
Model Setup
In this step mesh and boundary conditions are generated. By this time, you should already know the dimensions of the billet.
Name
Workpiece Mesh
Mesh Type
The wizard allows choosing one of the three types of meshes, i.e, Coarse, Medium or Fine mesh. Wizard generates workpiece mesh with all HEX8 elements.
Tool Mesh
Mesh Type
Tool components are exported as HEX8 elements. However, at present, tool deformation analysis is not performed.
Manipulator Length
This length is used to generate the clamp/manipulator contact BCs on each end of the workpiece.
Boundary Conditions
The outer surface of the workpiece is divided into three types of BCs.
•Outflow BC -  at each end of the workpiece
•ClampSurface BC – surface of the billet that comes in contact with manipulator/clamp at each end of the workpice
•PunchContact BC – represents the surface of the billet that can come in contact with the dies/punches
Die Contact Heat Transfer BC
You can specify one of the allowed three types of contact heat transfer conditions.
•Heat Flux
•Convection
•Temperature
forging_wizard_modelsetup
