Manufacturing Solutions
menu config subpanel
The menu config subpanel allows you to change the size of the menu or graphics fonts.
The menu font is the font used on the panels.  The graphics font is used when entity IDs, one-dimensional element handles, and legends are displayed.  The current font size is displayed.  You can also change the cursor size.
If you choose to use a Utility menu (activated via the View menu) you can specify the desired macro file in the macro file = field.
How do I...
Change the font size
Change the cursor size
