Manufacturing Solutions
HyperForm Post Processing
A number of utilities are available specifically for the post processing of sheet-metal forming, simulation results.
To access these utilities, from the HyperWorks File menu, select Load > Preference File > HyperForm Utilities. A drop-down list appears with the following options:
Utility
Distance Comparison
Calculates the distance between a part and reference part, and contours the distance on the reference part for the current time step.
Blank–Tool Gap
Calculates the distance between the tools and blank for a selected time step, and then posts the contour in a new window. For this utility, you need to specify the blank object as an input.
Import and Trace Line
Imports a CAD data line, via the Line Tracing panel, and traces it back to its initial step from the final step. For this utility, you need to specify the line and the blank object as an input.
FLD
Opens the FLD panel.
Section Cut
Opens the Section Cut panel.
Draw-In Plot
Measures draw-in, via the Measures panel, at desired locations of the blank on the tool face. For this utility, you need to specify the blank object and tool object as an input. For the tool object, select the blank holder for a single-action draw process, or the die for a double-action draw process.
Tensor-Plot
Opens the Tensor Plot panel and plots the major and minor strain on individual elements as a vector.
Export H3D
Exports results in an H3D file.
Export STL
Exports the deformed blank in an STL file.
Publish Report
Publishes results in an HTML file. You have the option to publish the following: a) deformed shape, b) plastic strain, c) % thinning, and d) FLD.
