Manufacturing Solutions
HMUNSUPPORTED
HMUNSUPPORTED
HMUNSUPPORTED
NAME
HMUNSUPPORTED - An import comment to indicate to the reader that info in this section should be retained in the unsupported area of HM.
SYNTAX
HMUNSUPPORTED BEGIN
Comment 1
Comment 2
Comment 3
HMUNSUPPORTED END
TYPE
HyperMesh Comments
DESCRIPTION
An import comment to indicate to the reader that info in this section should be retained in the unsupported area of HM.  This comment is used in pairs, with the type argument indicating the beginning or end of the comment block.
type
BEGIN, END
comment
Any desired text
SUPPORTED SOLVERS
See Also:
HyperMesh Comments
