Manufacturing Solutions
HMSET
HMSET
HMSET
NAME
HMSET – An import comment to sort & organize entity into sets HM.
SYNTAX
HMSET id entity_type name
TYPE
HyperMesh Comments
DESCRIPTION
This comment is used to signify that the following set was created by you in HyperMesh and not while the deck was being output by the templates.  This changes the method by which the set is imported into HyperMesh and how it is associated with groups.
id
Unique entity type identification number.
entity_type
ASSEM, BEAMSECTCOL, BEAMSECTCOLS, BEAMSECTS, BLOCKS,  BLOCKS, CGAPG, COMP, CONNECTOR, CONTACTSURF, CONTROLVOL, CSURF, CURVE,  CWELD, DDVAL, DEQUATIONS, DESVARS, DLINKS, DOBJREF,  DVPRELS, GROUP,  LOADCOL, LOADSTEP, MAT, METADATA, OBJECTIVES, OPTICONSTRAINTS, OPTICONTROLS, OPTIDSCREENS,  OPTITABLEENTRS, OUTPUTBLOCKS, PLOT, PROP, SENSOR, SETS,  SHAPE, SYSCOL, VECTORCOL, “regular/formula”
name
A name given by you to help organize the model or describe the entity.
SUPPORTED SOLVERS
OptiStruct
LS-DYNA
Nastran
See Also:
HyperMesh Comments
