Manufacturing Solutions
HMENDDOC
HMENDDOC
HMENDDOC
NAME
HMENDDOC - An import comment to that indicates the end of the model documentation into HM.
SYNTAX
HMENDDOC
TYPE
HyperMesh Comments
DESCRIPTION
The $HMENDDOC card indicates the end of a card used for model documentation. Any number of comment lines can be placed before this line. The beginning of this block is indicated by a $HMBEGINDOC statement. Only one model documentation block is allowed per model. Upon import, the comments within the block are placed in the control card “Model Documentation”.
SUPPORTED SOLVERS
OptiStruct
PAMCRASH 2G
See Also:
HMBEGINDOC
HyperMesh Comments
