Manufacturing Solutions
HMBEAMSEC
HMBEAMSEC
HMBEAMSEC
NAME
HMBEAMSEC - An import comment to sort & organize property types and info into HM.
SYNTAX
HMBEAMSEC type prop_id beamsec_id
TYPE
HyperMesh Comments
DESCRIPTION
This Comment appears above /PROP/BEAM & /PROP/TRUS definitions. When reading an input deck that includes these comments, Hypermesh takes the Ixx,Iyy & AREA values from the HyperBeam comments definition.
If you want to edit the card image values for such property cards in a text editor instead of using HyperMesh, then this comment has to be deleted--else the Ixx,Iyy & AREA values present in these Prop card definition are not taken into consideration, but instead the values from the Hyperbeam comments Association definitions (i.e. data following ##HMNAME BEAMSECTS) are taken.
type
PBARASSOC, PBARLASSOC, PBEAMASSOC, PBEAMINTASSOC, PBEAMLASSOC, PBEAMLINTASSOC, PRODASSOC, PTUBEASSOC, PWELDASSOC
prop_id
Unique property identification number.
Beamsec_id
A beam section identification number.
SUPPORTED SOLVERS
RADIOSS
OptiStruct
ANSYS
PAMCRASH 2G
PERMAS
See Also:
HyperMesh Comments
