Manufacturing Solutions
Generate Polymer Boundary Conditions
This macro is used to create all the BCs and assign process conditions for all polymer layers. This automatic generation is a complex step and is not guaranteed to be 100% accurate. Hence, you are required to inspect the model before submitting the data for analysis.
