Manufacturing Solutions
Element Connectivity
This data specifies the element type, what nodes form the element, and the component name of the element.
BEGIN ELEMENT NUMBERED MATID
Element type
Element-ID  Node_1  … Node_n Component-name
END
Following element types are allowed.
8-node linear brick (HEX8)
20-node quadratic brick (HEX20)
27-node quadratic brick (HEX27)  – this is not supported by the interface
BEGIN ELEMENTS NUMBERED MATID
 HEX8
   11   6 8 4 3 1 22 10 21  preform
   12   4 3 7 9 10 21 23 24  preform
   13   8 2 3 5 22 26 21 25  preform
   14   3 5 9 11 21 25 24 27  preform
END
