Manufacturing Solutions
Details Tab
Details Tab
Details Tab
The following table lists the items that may appear in the Details tab along with descriptions for each. The items that appear in the tree depend on the active process type. Complete details about RADIOSS settings can be found in the RADIOSS user manuals.
Control:
Memory
Termination time
The termination time for the job.
Animation Count
Adaptivity
Whether to use adaptivity.
Springback
Turn springback on or off
Thermal Option
Turn thermal properties on or off
Blank Type
Set the blank type to shell or solid
Summary:
Motion Summary
Displays a graph of time versus velocity of the parts.
Force Summary
Displays a graph of the time versus force of the parts.
Blank1:
Component
The HyperForm component that corresponds to the blank.
Material Type
Whether the material is from the materials database or a rigid.
Material: Name
Displays name of the material that was selected from the materials database. (Database type only)
Material: Thickness
The thickness value of the material. (Database type only)
System:
Global or local system.
Material: Constraints: Translation
Fixed, free, or along an axis.
Material: Constraints: Rotation
Loads
Contacts
Position: Clearance
The distance between the die and blank at the initial configuration for single action draw, double action draw and double action draw with support. Ignore the blank clearance for triple action draw.
Adaptivity
Write State File
Whether RADIOSS should create the state file.
Die:
Component
The HyperForm component that corresponds to the die.
Material: Type
Material: System
Loads: Load Motion
Load Motion: Type
Velocity Curve
Contacts: Friction
Coefficient of friction.
Position: Clearance
The distance between the die and the blank at the initial configuration.
Punch:
Component
The HyperForm component that corresponds to the punch.
Material: Type
Material: System
Load Motion: Velocity Curve
Displays a graph of time versus velocity.
Contacts: Friction
Position: Clearance
The distance between the punch and the blank at the initial configuration.
Binder:
Component
The HyperForm component that corresponds to the binder.
Material: Type
Material: System
Load Force: Force Curve
Displays a graph of time versus force.
Load Stopper: Max disp
Upper displacement limit for binder.
Load Stopper: Min disp
Lower displacement limit for binder.
Load Stopper: Max vel
Maximum velocity limit for binder.
Support:
Component
The HyperForm component that corresponds to the support.
Material: Type
Material: Name
Material: Thickness
Material: System
Loads: Load Force: Force Curve
Loads: Load Stopper: Max disp
Upper displacement limit for the support.
Loads: Load Stopper: Min disp
Lower displacement limit for the support.
Loads: Load Stopper: Max vel
Maximum velocity limit for the support.
Contacts: Friction
Position: Clearance
The distance between the support and the blank or die at the initial configuration.
