Manufacturing Solutions
cylinder full subpanel (Solids panel)
This subpanel creates fully-cylindrical, three-dimensional solid primitives.
solids_cylinderfull_example
Four inputs are required to create a cylinder using this method:
The bottom center node defines the center of the bottom cylinder face.
The vector between the bottom center node and the normal vector node is the cylinder axis, thereby defining the cylinder orientation.  This does not indicate the actual cylinder height.
The base radius defines the radius of the top and bottom cylinder faces.
The height defines the cylinder height.
See also
Solids panel
