Manufacturing Solutions
block subbpanel (Solids panel)
This subpanel creates three-dimensional block-shaped solid primitives.
solids_block_example
Four inputs are required to create a block using this method:
The base node defines the first corner on the bottom face.
Node 1 defines the corner of the bottom face that indicates the depth.
Node 2 defines the corner of the bottom face that indicates the width.
The bottom face of the block is then completed by rotating a copy of the triangle formed by these 3 nodes 180 degrees, and then matching the line between node 1 and node 2 for each triangle to create a parallelogram.
primitives_cube_1stface
Node 3 defines the corner of the top face that indicates the height and angle.
The vector from the base node to node 3 provides both the height and the angle for the block.  The parallelogram formed from the first set of nodes is translated along this vector to define the remaining faces.
See also
Solids panel
