Manufacturing Solutions
Criminale-Eriksen-Filbey Viscoelastic Model
In this model, the deviatoric part of the stress tensor is expressed as function of the viscosity and the normal stress coefficients.
criminale
This model can be used with any of the above mentioned non-Newtonian models and the specific model selected is used only to describe the viscosity of the material.   The first and second normal stress coefficient functions are described as an exponential function of the computed shear rate. In this specific implementation, the second normal stress coefficient is implemented as a function of the first normal stress coefficient.
criminale_02
Parameter
Units
Data Type
Typical Value
ViscoElasticModel
Two valid choices are “None” (default) and “CEF”
None
String
“CEF”
CEF_Coefficient1
Constant in the exponential function describing the first normal stress coefficient
Pa/s2
Constant
1.0e+04
CEF_Coefficient2
Constant in the exponential function describing the second normal stress coefficient
Pa/s2
Constant
-0.10
CEF_Exponent
Exponent in the function describing the first normal stress coefficient
None
Constant
-1.5
