Manufacturing Solutions
Create a New Material
1.From the RTM Utility menu, click Material Data. The Select and Assign Material from Database dialog is displayed.
2.Right click on a material directory in the top left panel and select New Material. New fields appear in the bottom panel.
3.Type a name for the new material in the Material name: field and select the type of material in the Material class: drop-down list. Click Next.
4.For Preform and Resin material type, the necessary options display. Select and click Next.
5.Type values for the various material properties in the fields that appear and click Create.
