Manufacturing Solutions
Check Element Settings Window
Previous topic Next topic Expand/collapse all hidden text
Use this dialog to determine which version of each element check to use.
Each check can be set to use a different solver’s check method, or you can set every check to use the same method. When a specified solver does not support a certain check at all, HyperMesh uses its own method for that check.
elemchecksettings
How do I…
hmtoggle_arrow1Set all checks to the same solver's methods
1.Open the Element Check Settings window:
2.Under the heading Solver Settings, click the All Set To radio button.
3.Select the desired Solver from the list box located to the right of the All Set To radio button.
4.Choose the Method used to calculate element Minimum Length/Size.
5.Choose the Method used to calculate element Jacobian values.
6.Click the 3-D tab to bring it to the forefront.
7.Choose the Method used to calculate 3-D element Minimum Length/Size.
8.Choose the Method used to calculate 3-D element Jacobian values.
9.Finish by:
Clicking Apply to keep the new settings, and then closing the window.
Or
Clicking OK to keep the new settings and close the window automatically
Or
Clicking Cancel to close the window without saving the new settings.
hmtoggle_arrow1Set each check method individually
2.Under the heading Solver Settings, click the Set Individually radio button.
3.Select the desired Solver from the list boxes located to the right of each check.
7.Choose the Solver to use for each of the 3-D checks, just as you did on the 2-D tab.
8.Choose the Method used to calculate 3-D element Minimum Length/Size.
9.Choose the Method used to calculate 3-D element Jacobian values.
10.Finish by:
Or
Or
See also
How Element Quality is Calculated
Check Elems Panel
