Manufacturing Solutions
arc center subpanel (Nodes panel)
This subpanel creates a nodes at the center of the arc that best approximates the input set of nodes, points or lines.
For nodes and points input, a minimum of three must be selected.
nodespanel_arccenter_nodesexample
For lines input, the selection must not result in a straight line.
nodespanel_arccenter_linesexample
An existing arc is an ideal input.
nodespanel_arccenter_linesexample2
However, almost any set of lines will also work, even if they are not connected, as long as they do not form a straight line.
An optional tolerance is available to verify whether the calculated best-fit circle is sufficient.  If ignored, the best-fit circle is always calculated; otherwise, an error is returned if the input entities are not all on the circle within the specified tolerance.
