Configure the Results Browser
The Browser Configuration dialog allows you to change the entity types, columns, options, and toolbars that are displayed in the Results Browser.
Right-click in the Results Browser and select Configure Browser from the context menu to open the Browser Configuration dialog.
Figure 1. Browser Configuration Dialog
The options that are available depend upon the currently selected view mode.
The following tabs contain the available browser configure options:
  • Options tab
  • Entities tab
  • Toolbars tab
Command Buttons
Once you finish configuring the browser, click one of the command buttons to close the window and return to HyperView:
  • Click Apply to keep the new settings and remain in the window.
  • Click OK to keep the new settings and close the window.
  • Click Cancel to discard the changes (keeping the original settings) and close the window.
