Create Solver Differential Equations
  1. From the Project Browser, select the system to which the solver differential equation is to be added.
  2. Right-click on a system in the Project Browser and select Add > Control Entity > Solver Differential Equation from the context menu.
    OR
    Right-click on a solver differential equation folder in the Project Browser and select Add Solver Differential Equation from the context menu.
    OR
    From the Model ribbon, click the arrow next to the Controls tool set name, then select Diff Equations icon.
    The Add SolverDiff dialog is displayed.
  3. Specify a label for the solver differential equation.
    The label can be changed at any time.
  4. Specify a variable name for the solver differential equation.
    By default, variables names of entities in MotionView follow a certain convention. For example, all solver differential equation entities have a variable name starting with “diff_”. This is the recommended convention to follow when building models in MotionView since it has many advantages in model editing and model manipulation.
  5. Click OK to close the window or Apply to continue creating entities.
    Once a solver differential equation entity has been added to the model, the panel for the equation will automatically be displayed in the panel area.
