Graphic Entity Attributes
Model files are composed of many different parts, or entities. MotionView allows you to change the display attributes of each entity in a graphic. Visual properties such as shading, color, and mesh lines can be assigned using the Graphic Entity Attributes panel.
The Graphic Entity Attributes panel contains the entity list tree, entity attribute controls, and the color palette. You can also add material properties. Click the Graphic Entity Attributes button, , on the General Actions toolbar to display the panel.
Figure 1. Graphic Entity Attributes Panel
