*feinputwithdata2 - CFD
The CFD import options specified in the Import tab are written to the command file as a string array, associated with the *feinputwithdata2 command.
The CFD import options specified in the Import GUI are written to the command file as a string array, associated with the *feinputwithdata2 command. The easiest way to produce this array is to import a CFD file using the desired parameters, and then to examine the string array in the resulting command file.
Note that it is important to end all of these strings with a space, for example "ASSEMS_SKIP " as opposed to "ASSEMS_SKIP". Valid strings for the string array are as follows:
Custom Import Strings
"ASSEMS_SKIP "
"BEAMSECTCOLS_SKIP "
"BEAMSECTS_SKIP "
"BLOCKS_SKIP "
"COMPONENTS_SKIP "
"CONNECTORS_SKIP "
"CONTACTSURFS_SKIP "
"CONTROLCARDS_SKIP "
"CONTROLVOLS_SKIP "
"CURVES_SKIP "
"ELEMS_SKIP "
"EQUATIONS_SKIP "
"GROUPS_SKIP "
"LOADCOLS_SKIP "
"LOADS_SKIP "
"LOADSTEPS_SKIP "
"MATERIALS_SKIP "
"NODES_SKIP "
"OPTIMIZATION_SKIP "
"PLOTS_SKIP "
"PROPERTIES_SKIP "
"SETS_SKIP "
"SYSTCOLS_SKIP "
"SYSTEMS_SKIP "
"TAGS_SKIP "
"TITLES_SKIP "
"VECTORCOLS_SKIP "
"VECTORS_SKIP "
Component Creation Strings
"IMPORT_BYPROP "
"IMPORT_BY1COMP "
None
Solver Specific Strings
None
