Filter Run Data
Use the Filter tab to filter the run data included in a Fit approach.
- Go to the Filter tab. step and select the
Click the corresponding checkbox to activate a filter.
Filter Name Filter Description Filter Outliers Removes outliers. For more information about outliers, refer to About Box Plots. Filter Duplicates Removes duplicate information. Note: Filtering duplicates can cause unexpected results when using interpolating fits.Filter Bad Numbers Removes runs that contain undefined or unrepresentable data (NaN, inf, and so on). Filter Excluded Removes runs that were marked as excluded from post-processing in the source matricies. For more information about editing run matricies, refer to Edit the Run Matrix. - Click Apply.
